Motor: 4kw/5kw 48V AC Motor
Controller: Enpower400A
Battery: 150AH/48V Lead-acid or 105AH/48V Lithium
Warranty: 1 year
Max. Speed: 40km/h
Net Weight: 637.5kg
Max. Load: 400kg
Dimension: 2968*1290*2003mm
Charger: In/Off board, Enpower,17A
Charge Time: 8-12h
Endurance Mileage: >80KM
Min.Turning Radius: r<2.5m
Max. Grade Ability: <40?
Ground Clearance: 160mm
Direction Control: Helical Rack&Pinion
Tyre Size "off road 23*10.5-14"
Wheel Base:1700mm
Wheel Tread (Front/Rear): 900mm/980mm
Transaxle: 12.31:1
Frame Material: Aluminum
Brake: Oil Press Rear Disc or 4 Wheel Disc Brake+ Electronic Parking Brake
Besides:
Deluxe Foldable Seats
Curtis Battery Indicator
USB Port
Email: eric@risuntech.net
Whatsapp/Skype: +8618584622412
Web: risuntech.net
Warranty: 1 year
Max. Speed: 40km/h
Net Weight: 637.5kg
Max. Load: 400kg
Charge Time: 8-12h
Wheel Base:1700mm
Transaxle: 12.31:1
Besides:
USB Port
Web: risuntech.net
