BLACK WIDOW 2023
  • BLACK WIDOW 2023
    Motor: 4kw/5kw 48V AC Motor
    Controller: Enpower400A
    Battery: 150AH/48V Lead-acid or 105AH/48V Lithium
    Warranty: 1-3 years
    Max. Speed: 45km/h
    Net Weight: 637.5kg
    Max. Load: 400kg
    Dimension: 2968*1290*2003mm
    Charger: In/Off board, Enpower,17A
    Charge Time: 8-12h
    Endurance Mileage: >80KM
    Min.Turning Radius: r<2.5m
    Max. Grade Ability: <40?
    Ground Clearance: 140mm
    Direction Control: Helical Rack&Pinion
    Tyre Size: off road 23*10.5-14"
    Wheel Base:1700mm
    Wheel Tread (Front/Rear): 900mm/980mm
    Transaxle: 12.31:1
    Frame Material: Aluminum
    Brake: Oil Press Rear Disc or 4 Wheel Disc Brake+ Electronic Parking Brake
    Besides:
    Deluxe Foldable Seats
    Curtis Battery Indicator
    USB Port
    This gallery has 4 photos.
    Email: eric@risuntech.net
    Whatsapp/Skype: +8618584622412
    Log into Facebook to start sharing and connecting with your friends, family, and people you know.
    Web: risuntech.net
