I have a 1999 Cushman UTV that I am trying to get going. The cart was running until the motor smoked.
I had previously replaced the burnt up Curtis controller with an Alltrax AXE 500 amp controller w/plug brake. So when the motor went I replaced it with a G.E beast motor and also replaced the old White Rodgers solenoids in the f/r bank with an Albright SW202. Wired eveything with 2 ga. I retained the old w/r main solenoid. Put everything together and it will not move. I have wired it two ways, both schematics are from Alltrax doc.depot. (AXE -Plug Brake) and (AXE to EZ-GO).
I have about 52 volts going to main solenoid and I checked and the voltage goes across it when pedal pushed and get click. When I check the controller output by jumping between B+ and M- I get like 25 volts without pedal pushed and pushed it goes to 52 immediately instead of gradual climb. I am stumped any help appreciated. I probably am omitting key information for that I am sorry.
