how do you remove the brake drums on a 92 ezgo. I want to check the linings.
Brake removal?
jack rear up and than you need to take the axle nuts off.........its a splined axle shaft and it might not slide right off so have a hammer to tap around the hub also if you can while tapping try and pry it outward at the same time..........this is if it dosn,t come right off...............................Tom
if i didn,t like them so much i wouldn,t touch them...........
