carburetor questions (eh29c)
  • carburetor questions (eh29c)
    The cart I worked on last year came back today... this time it had dirt in the carb bowl and stuck needle valve.
    Question is this: there is a hose port on the side of the carb but the hose is missing. It is small (1/8 inch) next to the fuel inlet. I tried to plug it, but the thing wont run that way. I guess it is to draw vapors from the tank, but I see no place to connect. Does anyone know what this port is? What goes there?
    This is a robin 4 stroke about 12 hp.
    thanks
    Hello, those are just overflow outlets. There should be a 6 inch hose attached to it and run towards the bottom of the cart so that fuel can drain away from the engine.
      Hey Matti, I am back.
      If you are correct, then I think I have found the source of dirt in the carb!
      The parts diagrams have it shown with a hose but no more information. It is listed as "vent", I think.
      That makes sense. The hose must have fallen off. I will try to find a tiny air filter for it...cigarette butt maybe? Seriously, it might be better to route it back to the tank or something
      I know this...it wont run with vent blocked.
      Updated by grey; May 20, 2010, 09:25 PM.
        Posted earlier by grey
        Hi grey, no air gets sucked in through these holes so there is no need for a filter. EZGO just calls for about a 7 inch tube to be connected to it. Dirt in the carb is from dirty fuel, no good fuel filter or a cart that sat over the winter with out being started regularly. Make sure the owner drains the carburetor next year and puts a additive into the fuel tank so that it does not happen again.
          I have spent many hours cleaning these carburetors, why? because I am always too busy to start up my carts over the winter. Guess id rather spend my spring with a few cans of carb cleaner.
            hi i am having trouble finding parts for the eh29c. Specifically a carburetor rebuild kit. Do they make one and if so, where might i be able to find one.
              Posted earlier by n59mower
              Try the EZGO dealer
                eh29c engine runs nice and slow while in charging mode but when finished charging, will no longer run slowly like i need. what is solution? the carb appears to not have any set screws..please help.
                Updated by mlcak; April 25, 2012, 09:03 PM.
