I just aquired an EZ Go Utility cart with a Robin EH35C 2 cylinder engine. I have never had a gas operated cart before so I have a few questions...
first, the simple one... What kind of oil do I put in it? Besides the engine oil, do I need to lubricate any other parts, like the variable speed discs? If so, how do I do it? Is there a manual available for these engines somewhere?
now a little more complicated... the carubrator has 3 tubes attached to it, one is larger, about 1/4" seems to be the fuel supply line, then there are two much smaller ones, about 1/8" OD.. they go down and are just dangling there.. looks like one was plugged with some goo on purpose, the other one is just open, like maybe it broke off ? I have no idea what these could possibly be for... if it was a car, I would say they would be vacuum lines, but I can't imagine what purpose they serve here. It concerns me to have lines going nowhere. neither one fits very well.. they are kind of just loosely hanging from the carb. Any ideas on where these should propery go, or what to do with them would be apreciated!
My engine starts and runs ok, it has a bit of a squeal and a jerk when it goes into gear, I'm guessing the belts are the major cause of this, they are not in very good shape. Any idea where to get replacement belts for this?
The engine will not stop running when hot... even if I shut off the key, it sputters and keeps trying to fire, I found I kill it by closing the choke. I'm guessing there is carbon built up on the cylinder head..etc. Short of taking it apart and physically cleaning it up, is there some kind of treatment I can use in this engine to help remove the buildup? I know they have stuff for car engines for this purpouse, but I am not sure about using these products on such a small engine. any ideas on how to solve this problem would be apreciated.
