I go ridding and after about 15 minutes it dies and won’t start. After it sits for a little while it start back up. Need help
Trouble with cart running for a little bit then quits and won’t start until it sits for a little while
It sounds like it could stem from several issues. First we need to figure out if it’s completely dead or if the engine still turns over. This will help narrow down whether the issue is fuel related or electrical.
If the engine isn’t turning over at all, it might be dealing with an electrical issue like a bad connection or a failing component that heats up and temporarily stops working. However if the engine is turning over but not starting, it could be a fuel problem. This might involve the fuel pump, carburetor or even where the fuel lines get clogged and stop flowing properly. Knowing the exact year or manufacturers number would be really helpful. Different models have their quirks and common issues
Posted earlier by Lbarnett52H-198 ser# 9039839 EH29C don’t know year
This gallery has 1 photos.Updated by Michael Eddie; June 17, 2024, 10:38 AM.
