2010-2013 EZGO Gas Freedom TXT Wiring Identification
  • 2010-2013 EZGO Gas Freedom TXT Wiring Identification
    I have a 2013 EZ-GO TXT Gas Freedom Cart that I recently purchased. I'm in the process of cleaning up the wiring and need help identifying the wires in the attached image. The wires are located behind the selector switch.
    I think the #1 wire is for the reverse/back up micro switch which is not hooked up. I connected it and the back up beeper did not work. I do not know if multiple wires attach to the switch, or if the switch or beeper are bad?
    I'm not sure what's going on with wire #2, but I'll splice these together for now.
    The #3 connection has me curious as there are no two green wires noted in the wiring diagram and am not sure what they do?
    Regarding #4, it looks as if the white and black wires were cut at the gray sheathing. Does anyone have any ideas what they were used or intended for?
    If anyone can help, I would certainly appreciate it. An image of a similar cart's wiring would also be helpful.
    Hi, there i had similar issues when i bought my Ezgo golf cart. i have finally found a solution to this issue, you can check out this good article i have written on my website
      Posted earlier by kmwisinski
      Howdy! Sounds like you're diving deep into the wiring of your cart there!..and about them wires, reckon it's a bit of a puzzle, ain't it? For wire #1 that reverse switch might be playing coy. Sometimes, a missing connection might just keep that beeper quiet. Might wanna double check with the wiring diagram section
      Updated by RideonTractor; December 21, 2023, 09:10 PM.
