EZGO GXT 800 problem
  • EZGO GXT 800 problem
    I have a GXT 800 utility cart that I believe to be stock . I have read posts on here but have not seen this problem mentioned . When it runs it is strong , responsive and will restart when I come back to it the same day (and again if it’s close together ) .However if it sits for over a day will not start , just turns over .
    It has spark, compression and fuel , carb is/was a 23932-G1 .
    Observation’s
    1) While checking if it had fuel , I pulled line at carb and pushed gas pedal to pump fuel , more often than not when I replaced line it started up and went .
    2) Eventually it stopped going so I replaced carburetor with a 23932-G1 aftermarket correct carburetor/filter . The cart ran better than ever but when I went back to it 2 days later it did the same as before .
    Any suggestions on what to look at next ?
    TY
    Dan
