i have a old ezgo gas 1200 workhorse, 4 cycle robin engine, cart just suddenly wont start, no spark, started replacing coil, ignitor, still no ignition, fuel is there. so because it was so old, i replaced solenoid, voltage regulator, timing belt, set valve clearamce. so now, it wont crank but if i disconnect one or both connection to coil, it cranks. pretty sure i connected all the wires back. any suggestion is greatly appreciated.
engine will crank only when coil is disconnected
