99 EZGO TXT Drive Clutch
  • 99 EZGO TXT Drive Clutch
    Having trouble with the drive clutch sticking and then engaging at a higher rpm causing a squeel and big clunk.
    I can see it's sticking on takeoff and then it's fine, is the drive clutch rebuildable? I have been told yes and no???
    Is it best to just replace the drive clutch? I think the part number is 23817-g1.... anyone know if that is correct?
    1999 EZGO TXT Gas Robin EH-29C 295cc
    Found this on ebay........... EZGO Gas Golf Cart 1989-up Primary Drive Clutch 23817-G1 New Replacement | eBay
    Anyone use one of these? Thoughts>>>???
    Thanks
    PalAl
    Ok, did more research and found what i think is the correct part number for my drive clutch
    it is 26952G01, $500 to $600 to replace!
    Can this be pulled, cleaned, parts replaced if needed to rebuild or does it have to be replaced?
    Is there a blowup showing internal parts and numbers??
    I can't be the only one...................
    Updated by PalAl; April 20, 2021, 03:28 PM.
    If the bore size is the same it will work try a comet brand that ebay thing is just a copy of the comet. I know this is a very old post but Noone else seems to be here
    Updated by whiteGIANT510; February 13, 2022, 05:13 AM.
