Mad jax upgrade wire harness
  • Mad jax upgrade wire harness
    Good Morning all, I've got a 2016 Ezgo TxT with the Mad Jax upgraded wiring harness and it has a 9 pin connector, will this work with any aftermarket 9 pin turn signal assembly?? I know the new Mad Jax thats out there now has a 12 pin connector, what does the 12 pin do that different from the 9 pin. Thanks in advance.
    Update: I ended up buying the GTW Upgraded Tune signal kit, Installed it an its really a nice outfit. Trying now to get the daytime running lights working, I found out the red with white stripe bullet wire
    coming out of the back of headlight goes to the running lights, problem now is trying to find out what wire in my turn signal assemble would let me use my turn signal lever to turn on and off daytime lights.
    Thanks in advance for any help.
    Updated by Deuce1550; January 1, 2021, 07:52 AM.
      Update: I figured it out. Daytime running lights are now working as they should. On to the next project!
