I pulled my 2006 ezgo txt cart in shop and changed oil and when I finished servicing it will not start. I have checked fuel pump and fuel line and they are performing fine. I checked spark at wire end and through sparkplug and have a hot spark. I set valve clearances to .006 cold(they were all pretty close to begin with. I checked compression and got 75 on one and 80 on the other. I squirted oil in the 75 lb. cylinder and got only 120. My question is could the timing and or timing belt cause the compression to be reading low. It was running perfect when I pulled it into the shop. What do you think? Thanks, Jim
2006 Ezgo TXT quit suddenly after servicing and will not start
