1992 Marathon economy lift kit
  • 1992 Marathon economy lift kit
    Need help finding a video or any other info to lift my 1992 marathon gas golf cart
    This is a wonderful question! Consider how you plan to use the cart and what your budget allows. If you’re looking for an economical and easy to install solution for casual use, a block lift kit might be sufficient. For a good balance of performance and ease of installation, spindle lift kits are a solid choice. If you need something more robust for off road use, an A-arm lift kit offers great performance at a higher cost and complexity. And if you’re aiming for the best off road experience, a long travel lift kit, despite its higher price and installation difficulty, could be the way to go.
    Each type of lift kit has its strengths and is suitable for different applications. First, there are spindle lift kits, which are one of the most popular choices for golf carts.
    These kits replace the stock spindles with longer spindles, effectively raising the front of the cart. They are known for providing a stable ride and maintaining the original steering geometry. Spindle lift kits are generally easier to install compared to other types, making them a good option for those who are comfortable with basic mechanical tasks. They are also relatively affordable. Performance wise, they handle well on both pavement and light off road terrain.
    Next up are block lift kits, which are essentially spacer blocks that fit between the suspension and the frame of the golf cart.
    These kits are usually the most economical option and are straightforward to install, often not requiring any special tools. However, they don’t provide the same level of ride quality or stability as spindle lift kits. Block lift kits are more suited for casual use on smoother surfaces and are a good choice if you’re on a tight budget and primarily use your cart on flat ground.
    A-arm lift kits are another option and are known for their improved suspension geometry.
    These kits replace the entire front suspension with a new, longer A-arm setup, providing a significant lift and better handling, especially on rougher terrain. A-arm lift kits are more expensive and installation is more complex, often requiring specialized tools and a bit more mechanical know how. They offer superior performance for off road conditions, providing better ground clearance and suspension travel, which is great if you plan to take your golf cart on more adventurous outings.
    For the ultimate in performance, long travel lift kits are the top of the line choice.
    These kits provide the maximum lift and significantly improve the suspension system. Long travel kits are the most expensive and complex to install, typically requiring professional installation unless you’re very experienced with mechanical work. They are ideal for serious off roaders who demand the best in performance and durability.
    Here is a video explaining the installation process, if you have any questions feel free to ask!
