White wire on top of robin fugi 292cc
  • White wire on top of robin fugi 292cc
    There is a loose wire not connected to anything on the top of my 98 ezgo engine anyone know where it may plug into?
    The white wire since its on the top of the engine most likely goes to the ignition coil (see attached diagram) and is part of the wiring harness, if you have any questions let me know!
      There is also one white wire with a round female bullet connector coming out from behind the plastic cover near a red and black wire. On mine it was attached to an old pressure sensor although my cart had no OP gauge or light.
