I'm wondering if anyone else has run into the same issue as me. We have a fleet of '07 gas TXT's (MCI 2 cylinder) and several of them make a rattling/vibration noise from the engine that I'm struggling to pinpoint. Its none of the obvious metal plates on the outside of the engine. it does not vary with engine speed and the only way I seem to be able to make it go away is by applying pressure backwards (towards the rear of the cart) on the front engine mount/pivot. It sounds like an exhaust heat shield rattling around, but that is for sure not it.
anyone else run across this ???
Thanks,
Ben
Thanks,
Ben
