1986 ezgo gas 2 stroke will not start
  • 1986 ezgo gas 2 stroke will not start
    changed fuel pump,carb,unhooked exhaust getting fire and gas plug is wet. sprayed carb cleaner around crank seal. rpm did not change nor did it try to start. held string over carb opening and it would suck the string inside carb. sprayed carb cleaner in carb and
    STILL WILL NOT START
    Run a compression test ASAP
