Electrical Assistance Please.
  • Electrical Assistance Please.
    I have a Workhorse with the 350 in it and I'm experiencing an issue.
    It won't start/run electrically. The solenoid won't pull in. If I jump the contacts it will turn over, and If I put 12vdc to the coil it will start and run. The switch on the pedal is functioning, I checked voltage there.
    I didn't get much farther into the wiring yet but it seems there is a red wire coming from some sort of electrical component in the left front corner of the carts engine bay that needs to go hot and it's not.
    What do you folks think the issues, and where can I find a good electrical drawing for my cart?
    (It's the Wife's, and she's pissed when it's not running)
    Thanks All...
    TB
    Hello Tom,
    Did you try to replace the solenoid yet? If not, give that a try and that may sort out this problem.
