Which front basket for Ezgo
  • Which front basket for Ezgo
    Looking to buy front basket for a Ezgo TXT . Preferences - likes or dislikes. See them on Ebay . Are they much the same?
    Updated by dan2116; September 23, 2013, 10:38 PM.
    Front baskets come in various styles and mounting setups each offering unique advantages and considerations. Let's talk about mounting setups. Some front baskets are designed to be mounted to the roof posts of your cart, while others attach directly to the chassis. The choice between these options depends on your preferences and specific requirements. Baskets mounted to the roof posts often provide a higher position, which can offer additional clearance for items stored in the basket. Conversely, baskets mounted to the chassis may offer a lower profile, potentially providing easier access to the basket's contents and accommodations for heavy items.
    Choose a front basket that accommodates your cart's existing accessories such as windshields or brush guards, or leaves space to add these accessories in the future. Some baskets are designed to integrate with existing windshields or brush guards. However, other baskets may require modifications for proper installation or could potentially interfere with other accessories.
    Consider weight capabilities so that the chosen basket can safely support the intended load. Some baskets that mount to the roof supports are designed for light duty use, ideal for carrying smaller items like towels or snacks, while others mount to the chassis and boast robust construction suitable for heavier loads such as large coolers or heavy equipment.
    It's worth considering alternative solutions that may better suit your needs. One option is upgrading or installing a rear seat that flips into a flatbed for hauling. When not in use as seating, the rear seat can be easily converted into a flatbed, allowing you to transport larger items such as coolers, luggage, or even gardening supplies. This design maximizes the utility of your golf cart making it suitable for a wide range of tasks beyond the ordinary.
    This gallery has 3 photos.
