Was riding the other day, stopped to open a gate and when I depressed pedal, nothing happened. Tried several times and the solenoid on driver side in front of battery, would click but no crank. Used starter button and jumped across solenoid and it cranks. Called auto parts where I purchased it, they work on them also, and was told solenoid was bad. Replaced and still no crank. Micro switch under floor checked with meter and it operates as should. Inline fuse off solenoid is good also. Any ideas on what might be the problem?
EZ Go Gas will not crank
