'98 EZGO TXT Gas 4 Pass
Looking for a little help in the final bit of wiring for a couple accessories. Installing Turn Signal, Brake Lights, Horn, Alarm w/remote kill switch and LED Under body lighting.
EZGO Harness(H) 72228-G01 shows:
RED(H)from 15A Fuse block to BLK at 2 Prong Flasher
YEL from Turn Signal to 2 Prong Flasher
RED(H)from 15A Fuse block to RED at Brake Switch o-- C
BRN(H) to BLK at Brake Switch o NO
BRN(H) to the Turn Signal (Does not show to what color wire)
BRN(H) to both tail lights but doesn't show to what color wire.
EZGO Service Parts Manual for Tail lights(TL) shows:
WHT(TL) to BLK(H) - Both sides
BLK(TL) to BLU/WHT(H) - Both sides
RED(TL) to WHT(H) - Driver Side
RED(TL) to YEL(H) - Passenger side
RED(TL) to BRN(H) - (W/O Turn Signals)
Turn Signal(TS) Diagram shows:
BLU(TS) to WHT(3 Prong Flasher)
BLK(TS) to BLK(3 Prong Flasher)
+12v Supply to RED(3 Prong Flasher) w/Fuse
ORG(TS) to Brake & Turn - Driver side
BRN(TS) to Brake & Turn - Passenger side
RED(TS) to Brake Light Switch o--
+12v Supply for brakes to Brake Light Switch o
I took a 9 pin connector and made it so the wires from the Turn Signal can connect at the base of the steering column to the harness wires for a clean look. The way I see it:
BLU(TS) to WHT(Flasher)
YEL(TS) to GRN(Left Front Turn)
WHT/BLK(TS) to BLK(H)
GRN(TS) to DRK GRN(Right front turn)
ORG(TS) to WHT(Left Rear Turn)
BLK(TS) to BLK(Flasher)
WHT(TS) to Frame Ground
BRN(TS) to YEL(Right Rear Turn)
My confusion is if I connect the remaining wires the way both diagrams show, will it be connected correctly:
+12v Supply for brakes to Brake Switch o
RED(TS) to Brake Switch o--
RED(H) from 15A Fuse block to Brake Switch o-- C
BRN(H) to Brake Switch o NO
Where do I connect the other two ends of the BRN(H) that end at the turn signal and tail lights?
Thank you in advance
