I have a 1996 EZGO with Robin EH29C engine. We were having issues with it slowing as we were driving, then it stopped completely. The engine would run, but would not "go". We removed the carb for cleaning. Either the pin that holds the float broke while riding, or was broken while cleaning it. We replaced the old pin with a small nail the same size. Reset the float. Replaced spark plugs, hose from fuel tank to pump, starter belt, changed the oil, and replaced small hoses for vents on side of carb.
The cart now runs, but doesn't seem as strong uphill and is very noisy. A friend said the carb is for a 350cc and we have a 295cc. How can you tell what size carb you have? Also, we could not remove the main jet in the carb. Any tips on removing for cleaning? Any suggestions are appreciated!
