2001.5 TXT Gas..I think my solenoid took an $H!T. When I step on the gas pedal I hear a clicking from the solenoid. I am thinking it finally went. I am also going to check the battery to make sure it hasn't gone out on me. I know there is some way I can ohm the solenoid to check if it is good. Does anyone know how to do this and the steps? If it is bad I am going to replace it. Someone recommended to upgrade to a 14volt one from the standard 12volt, do you know why I would need to do that? Where is a good place to buy these at?
Thanks!!
Thanks!!
