ezgo gas not starting or turning over
Hi I have an old ezgo gas 4 stroke with a robin 2 cyl motor and until tonight it runs just fine. I was spraying the weeds and had just shifted from rev to fow and when i nstepped on the gas ---nothing --- all i can hear is the micro switch that connects when you start to move the gas petal make a clicking sound but the electric motor does not start turning? any ideas?
Tags: None
If that doesn't fix it. Make sure your battery is fully charged. Move clutch by hand bout a 1/2 turn. This should also turn the starter to a new position. Try to start. If it starts you probably need to change out the brushes in your starter.
