Engine replacement kit.
  • Engine replacement kit.
    Does anyone know of a good engine replacement kit for an 1998 EZ-GO TXT? It currently has a Robin 295 in it and I would like to replace it. This is not a lifted cart so I can not do a big block. Thanks
    If you're thinking about replacing the Robin 295 you might want to check out the install kit from VegasCarts for the Predator 459cc or 420cc engines. It's a pretty straightforward setup and doesn’t require lifting the cart which is perfect since you mentioned it’s not lifted. A lot of people seem to go this route because it’s an easy way to get more power and torque without breaking the bank or needing any crazy modifications.
    The nice thing is the kit comes with pretty much everything, engine mount, drive belt, muffler, and some options for clutches if you want to upgrade. The only thing you'd need to pick up separately is the engine itself from Harbor Freight, which keeps the cost pretty low overall. Harbor Freight offers coupons for these engines during major sales events like holidays which can help lower the cost even more. The 459cc has about 15.8hp and the 420cc has13hp. If you're looking to give the cart a bit more kick without too much hassle it might be worth checking into the details to see if it’s a good fit for you.
