New to me is a 99 EZGO with an EH29C engine. Starts very easily and runs with lots of power.
A couple weeks ago we started checking it over and if we remove the oil filler with it running, there is all kinds for blow-by coming out with some oil splashing out. Didn't seem right.
Compression checked at 60 lbs almost exactly on both cylinders. Is this low???? Is ring or valve problems a possible source of the blow-by?
Now the kicker. Today we went back down to the lake and went for a spin in the EZGO. The temp was in the mid 60's and it seemed to start just a little bit harder then normal with no choke. Once warmed up after a minute, ran like normal. When we got back a small puddle of oil formed on the ground. Further investigation showed what looks like oil is blowing out from under the rocker cover. Like I have now blown a rocker cover gasket.
From the information above, how bad is it? Is there anything that can be looked at easily or are we looking at an overhaul?
Appreciate any comments.
Gary
Gary
