I swapped out a 295cc for a 350cc engine but I do not know the year of the 350cc. I need to buy the correct carb but have to figure out which year of engine I have before I can get the carb. The timing belt cover doesn't have any info on the motor and the only marking I can find says the motor is a eh35c robin engine. Does anyone know how I can determine what year of engine I have?
What engine do I have?
The only real difference is the jet. A simple performance mod for the 295 is to put the 350 jet in the 295 carb. I did it when had a 295 and it madea noticeable difference. But when I went to the 350, I drilled out the jet a little more. I do only recommend that if you are able to do so with a drill press and do it in very small steps.
