Rough Ride
  • Rough Ride
    I just bought a 97 EZ GO Gas cart with a lift kit. It has 22X11-10 desert dog tires which do not seem to run true. Some have about a 1/2" difference in runout when I spin the tires just barely lifted off the floor. Is there a trick to center the wheels or could the tires be off the beads on the wheels.
    The cart set for 4 years and the tires had little air when I bought the cart.
    I put 7PSIG in the tires.
    There are no tricks I know of to center the tread.
    Are these DOT rated tires? Lesser types are not known for their quality construction.
    If these sat for years you could try breaking them down and reseating them.
    Although 7psi is probably the right pressure, try upping them to 20psi when seating then reduce to 7psi.
