is there a trick to removing the clutch and starter pulley 295 cc engine.I need to get timing cover off and i don't think its coming off without taking it off.
clutch removal
Posted earlier by cm4duxis there a trick to removing the clutch and starter pulley 295 cc engine.I need to get timing cover off and i don't think its coming off without taking it off.Regards
Does anyone have an EZGO clutch puller they are willing to rent?
That was a really dumb question ... I posted this before I learned how simple the pullers really are and how they work. I envisioned a huge 3 jaw puller or something similar. It should not be too hard to make one. One important thing seems to be getting a rod of a sufficient diameter to not damage the threaded hole in the end of the crankshaft.Model Year: 1994
Make/Model: GX444 4-cycle Gas Marathon
Serial # 810988
Manuf Code G1794
I made one out of I believe it is a 3/4" fine tread bolt and like you said a piece of rod. I have it at work, if you still need dimensions let me know and i will get them. It actually works better than the factory puller if it’s a 94 medalist or newer.
