on my 99 295cc carb. There is a plastic adjustment on the top of the carb. It has a stop so it will only turn each way so far. It now points toward the filter. Trying to make sure the throttle value is closing completly. Thanks
295cc Carb
Posted earlier by ronson55on my 99 295cc carb. There is a plastic adjustment on the top of the carb. It has a stop so it will only turn each way so far. It now points toward the filter. Trying to make sure the throttle value is closing completly. Thanks
If you are looking to adjust the throttle valve, it is the screw that is pretty visible near the throttle cable. Remove the air filter and look inside at the flap and peer in to see if it is closed all the way while playing with the gas pedal. If not, adjust either the cable or the flap screw.Regards
