What are thesymptoms of overfilling EZ GO engine with oil? We have a 2007 EZGo that is used by many different operators that I believe do not understand the oil fill line on the engine. They check and fill the oil, as asked however it seems constantly over full. The plugs are constantly oil fouled, and as the engine gets warm it burns quite a bit of oil out the exhaust.
oil overfilling
Matti, I have a lifted cart and I changed my oil this weekend and ever since it is smoking bad. I think the manual called for 1 & 1/3 quarts but it ended up taking all 2 quarts before it hit the full mark. Did I overfill it? If that is the case how do I know how much to put in? Shouldn't the dip stick be accurrate?Updated by goody9825; January 30, 2012, 05:07 PM.
Posted earlier by goody9825Matti, I have a lifted cart and I changed my oil this weekend and ever since it is smoking bad. I think the manual called for 1 & 1/3 quarts but it ended up taking all 2 quarts before it hit the full mark. Did I overfill it? If that is the case how do I know how much to put in? Shouldn't the dip stick be accurrate?Regards
Posted earlier by goody9825Should I drain it or just let it burnt out? Will it damage the engine if I burn it out? Why on lifted carts does it not register properly?
On lifted carts, it does not register properly because when you lift a cart it knocks the point of balance off. So the engine is not laying flush to the ground anymore. That is a reason why most lift kits are not "Ezgo Certified", because it throws off certain aspects of the golf cart that were once tested by EZGO, like the oil level.Regards
