05 ezgo rearend
  • 05 ezgo rearend
    how much will it cost me to replace the rear end on my 05 ezgo txt. It is making a bad grinding noise.
    Updated by scope; September 8, 2011, 09:53 AM.
    It's rare that you would ever need to replace the rear end on an Ezgo cart. Could be you need to adjust the cable or maybe you have a bad axle bearing.
    Have you checked the oil level or changed it?
      Just for reference, the cost of a used rear if you can find it would be around $600. Rebuilt unit probably around $1000. EZGO will probably charge you 200-400 to install.
