One more dumb question
  • One more dumb question
    On a 1982 model, what is the purpose of the contraption on the outside of the engine on the flywheel housing. It has a fitting for a gas line?? and a connection for a cable. The cart has both disconnected. Someone has also cut the wires to the limit switch on the throttle and replaced it with a toggle switch. I'm assuming, if I ever get this thing running, that the toggle will have to be used every time I come to a stop??
    thanks, pdavid
    Posted earlier by pdavid
    thanks, pdavid
    Hello David. That would be the carburetor.
      No Matti,
      I maybe dumb but I'am not that dumb, I know what a carb looks like. I think what i'm looking at is part of the oil injection system that has also been disconnected.
      pdavid
        No Matti,
        pdavid
        Okay good. If it is the oil injector, it is possible that it is disconnected because they bypassed it, since they have a tendency to stop working with out warning which can run your engine dry of oil and seize it up. Is it possible you could post a detailed picture of it?
