New to the forum. Looking forward to some good advice.
1993 Marathon with 295cc Fuji Robin.
Takes forever to get started. If you only hold the gas peddle down half way it will start quicker but still takes way to long. Once it begins to run. its only on 1 cylinder at first then slowly the second cylinder with join in. It also back fires through the carb the whole time its trying to start. I have new plugs. Good fuel. Plenty of spark.
I would like to do a rebuild in the near future but need it thru the race season. What is the most cost effeicent company to buy the parts to do a rebuild.
I will probable bore it and put new pistons in it. Redue the top end and berrings and gaskets.
I can't see spending $1,000.00 like most of the sites I have rebuild kits. I just want to freshen it up.
I also remember someone had a better cam shaft for higher top end running, but can't find that link. does anyone have it?
One more thing does anyone have a pdf of how to do a rebuild on this with torq specs?
Sorry for so many questions.
