EZ Go Medalist - Wont Go
  • EZ Go Medalist - Wont Go
    We have an EZGO Medalist. All batteries are less than 2 years old and all check out. Showing good votlage at all connections.
    When the cart is jacked up off the ground and pedal is depressed, the rear wheel makes a slight turn either forward or reverse (not even a 1/4 of a turn)
    Looking for where I go from here.
    Any help will be appreciated.
    Thanks in advance,
    Ken
    I'm having the same problem with my 99 EZGO Freedom SE. It happened early in the summer and they put me a new F/R switch board on to fix it. It's doing it again and I decided to check in here to see if anything other than the same switch could be causing the problem.
    All I hear is a click when I press the pedal. I've got good readings on the batteries and the solenoid tests good.
    Still looking.
      Do they have a control box on them?
        Sounds like a bad speed controller. I don't know much about checking them out.
