Hi Guys,
I picked up a 2000 EZ-GO, it had weak batteries so I replaced 4 of them and kept the best 2. The cart runs great. The charger on the other hand is not working, here's what I have so far-
Power Wise 36 Volt Charger
When I first tried it, nothing, no power, no charging.
Opened up the case and found the 50amp fuse blown so I replaced it. I plugged the charger in the wall outlet first and when I tried to plug the cart in it was like a dead short, even did a little welding
. After I cleaned up the cart plug with my Dremel and changed my shorts, I tried again with the cart plugged in first, but as soon as I plugged the charger into the cart the 50 amp fuse blew. (the charger was not plugged into the wall outlet) Soo I thought maybe some DPO had changed the polarity on charging plug that's wired to the batteries, I switched the 2 wires and tried again, the fuse blew as soon as I plugged the charger to the cart, again, not plugged into the wall outlet.
I have checked the capacitor with my ohm meter seems ok -no short
I am assuming the transformer is ok
Have pulled both circut boards, nothing obvious- of course, am assuming the problem is with one or both.
any input would be appreciated.
Thanks Jim
Thanks Jim
