EZ GO wont go
  • EZ GO wont go
    My 1992 EZ Go will not go front or back. If I load it on the trailer and tow it down a bumpy road it will run the rest of the day. But next day it does the same thing. Does any one have any ideas? What tests can I perform? Thank you for any help.
    Tap on the solenoid the next time it quits. If it doesn't run, jump it by running a 6 gage wire across the 2 large posts. If it runs, replace the solenoid.
    If it still does not run, check around for loose connections.
      I will give it a try.
      Thank you very much!
