So i have a 1998 ez go and i just changed the batteries because the old ones were losing power, so i put 6 new batteries in it. I drove it around for about 3 weeks and now its losing power realy quickly like it did with the old batteries. i need help!
New battery power loss
Always give the cart a good initial charge when installing new batteries
To diagnose your problem, first make sure the batteries are hooked up in the right order by a wiring diagram. Next, fully charge the cart. When the cart is charged, run a test on each battery to check the voltage. Then run a load test on each battery after that.Regards
Posted earlier by rob1621ok well i was just looking at the batteries and while the car is charging if you open the tops of the batteries, the acid is bubbling in the last five but the 1s battery doesn not bubble like the others...Regards
Posted earlier by MattiAlways give the cart a good initial charge when installing new batteries
