how to install the power meter
  • how to install the power meter
    Hi, I bought a 36 volt power meter for my EZGO off ebay but the guy never sent me directions on how to install it. Can anyone help me. Thank's, Jim
    They do make a few different ones, what kind of posts are on yours and is it digital or analog?
      my meter is analog and for post it has a minus post and a plus post. jim
        I see, here is how its done. Hook the plus post to the battery pack positive. Then hook the minus post to the battery pack negative. This will hook the meter up so it is always on (which uses close to no power at all).
        If you would like the meter to turn on and off when using the key, hook the minus post on the meter to the battery pack negative... and then hook the plus post on the meter to the switch terminal on your key switch.
          Matti which battery do you hook the postive to and the negtive to the?the last battery negative and the first battery positive
            Correct which ever 2 batteries the charger plug cables run to are the one you use.
              Thanks again andy thought so just double checking
