We changed the battery but didn't notice the key was left on ( not sure if this part is even relevant)
wlwe swapped the battery out because the cart wouldn't turn over or would be slow to run
After swapping the battery the box with gep on top of it started buzzing when the battery was reconnected and when the key is turned on you can feel it buzzing and hear it the box only has 2 fuses and a relay in it we called a dealer to track down a new relay but even the new one buzzes when the key is turned on I don't know where to start on this issue and would appreciate any help that can be offered
