Requests for using power from 604884 DC/DC converter; green & black wires
  • Requests for using power from 604884 DC/DC converter; green & black wires
    Textron Label:
    Model: RXV FROM ELEC
    Date Code: E2812
    Recently purchased this EZGO Freedom RXV; has turn signal bulbs but no mechanical switch to operate them. Installed Red Hawk LGT-113 Turn Signal Kit without any issues with the exception that the instructions states remove & re-install the flasher which turns out is no longer included in the kit as the electronics had been moved into the control box. Further inspection of the golfcart reveals the DC/DC converter as shown in the EZGO Electric RXV 48V Parts Manual listed as part number 604884, item #18. There is a multi-pin plug and 2 large terminated wires (Green & Black with white tracer) with the DC/DC converter. I measured something zero ohms from the Black wire to the “negative” terminal of the batteries via last battery in series. The Green wire measures 13.51 only when switched ON using the key. I have not been able to find information if this 13.51 is available for accessories and what the wattage/amperage might be. Any help on this matter would be greatly appreciated.
