Hello all,
I have an Ezgo TXT, 36v cart. I run the cart for under five minutes and the controller, solenoid, and motor gets very hot. If I keep driving the cart will slow and come to a stop. Cool it down and it will limp along. Leave it to cool completely and you can do it all over again.
So far....
Sent the cart to a shop, and they replaced the solenoid and resistor. Tested batteries, and checked everything over the cart. They said there were no issues.
Same issues
I sent the controller out and had it rebuilt. Came back with a good bench test. Also rebuilt the charger. Tested the speed controller, and everything else I could think of, nothing.
Same issues
Took the batteries out, installed three brand-new commercial 12v batteries, and cleaned up all connections and cabling.
Same issues
I tested the motor itself, and found some ohms reading to the housing. Sent the motor out and had it rebuilt and bench-tested.
Same issues
So I got four stock wheels, and that made no difference.
Could the wire size between the batteries and the motor be causing this? Currently, there is a No 6 to everything.
I am open to any ideas or thoughts. Locally I have talked to 4-5 cart shop mechanics and none of them have any idea.
TIA ! ! ! !
So far....
Same issues
Same issues
Same issues
Same issues
TIA ! ! ! !
