I am installing two buggy whip lights on my 2016 EX GO Electric cart. Basic wiring of one neg and one pos cable but I am curious if it's best to install on one battery or between two. Looking for advice on this.
Buggy Whip Install
Nice!!
It's always best to run accessories through a pack voltage to 12 volt reducer. The main reason is so that power is drawn evenly from the entire battery pack preventing any one battery from being overworked.
If you have access to a 12 volt source, like if you're running four 12 volt batteries, you could technically tap into one battery to power your lights. However, doing so would cause an imbalance in your battery pack over time. The battery you tap into will discharge faster than the others, leading to uneven wear and reducing its lifespan. Over time, this can cause problems with the entire pack, the batteries will no longer charge and discharge evenly. The imbalanced battery could drag down the overall performance. Although, tapping into one or two batteries for 12 volt power is common practice by manufacturers, its done to simplify wiring and reduce costs, though it can lead to uneven battery wear over time.Updated by Michael Eddie; August 11, 2024, 10:31 PM.Regards
- Likes 3
Michael Eddie Thanks agains for the advice. Reducer and whips installed! I have a video but it would not upload.
This gallery has 1 photos.
- Likes 4
