2000 EZGO TXT Manuf. Code F200 Serial number 1278175
  • 2000 EZGO TXT Manuf. Code F200 Serial number 1278175
    Hi, my 2000 EZGO TXTwon't go in reverse anymore. Forward no problem. I put a new switch in the dash panel, no results, I switched the wires at the back. When I select now reverse the cart move forward. That indicates the switch is OK. Any suggestions please? I could use some advise. Can anybody tell me where the fuse box is located so I can check the fuses? I assume there is not a separate fuse for reverse only.
    Thanks.
    Updated by Golfcart1305; October 6, 2023, 02:22 PM.
