Can I remove the back up buzzer on a ezgo golf cart
Ego rxv
locate the reverse buzzer on your EZ Go golf cart, follow the steps below. Step 1: – You need to access the right side of the cart opening and locate the key switch panel. Step 2: – Now, look behind the key switch panel. This panel is very easy to access, and that is where the reverse buzzer is located. locate the reverse buzzer on your EZ Go golf cart, follow the steps below. Step 1: – You need to access the right side of the cart opening and locate the key switch panel. Step 2: – Now, look behind the key switch panel. This panel is very easy to access, and that is where the reverse buzzer is located.
