1997 EZGO wont run
  • 1997 EZGO wont run
    I'm new to the forum and need help. I have a 1997 EZGO that was upgraded from 36v to 48v. An Alltrax NPX4834EZ with ITS controller was installed. The cart quit running. I noticed that the original solenoid was a 200 amp (controller is rated for 300), so I replaced it with a 300 amp heavy duty solenoid. I tested the ITS, solenoid resistor, wiring, reed valve and they are working. The controller is displaying no defects (solid green indicator). I measured between M and B+ tabs on the controller. Static state reflects 25v and increases as you push down the pedal. I tested the voltage at the motor and at static state with key on, it reads 50v at S1/S2 (not sure if this is correct because the numbers are gone), and read 25v at A1/A2. As you depress the pedal, A1/A2 drop to 0 v and S1/S2 stay constant at 50v. I also tested the controller at tabs B- and M-. Controller showed 25v at static (engaged solenoid) and drops to Ov as you depress the pedal. What am I missing?
    Figured it out. Bad F/R switch.
