EZ GO Wants to move
  • EZ GO Wants to move
    Hello all, this is my first time on a forum. I could use a little help. I have a EZ GO TXT and the batteries check good. It wants to go forward and reverse cause it gives a little jump and then it pulses like when the batteries die and it don't move. I live in south Louisiana and the humidity been bad the last few weeks. The cart been sitting for about 3 weeks under my carport. I'm just wondering if anyone ever had this problem before. It was working fine before it sat. Any help would be appreciated.
    Had this problem with my rxv and ended up being a bad connection to the speed sensor. After fixing the wire it was back in action. For an experiment I unplugged the speed sensor and it repeated the same symptom. It was going into limp mode due to no ground pulse from the sensor. Not sure if txt is the same but something to check.
