ezgo txt 36 volt
  • ezgo txt 36 volt
    Motor wire from shift controller to motor get hot and melts connector is the motor going bad and how can I check it?
    Sounds more like the FNR switch needs to be disassembled and the contacts cleaned thoroughly.
      Replace the FNR switch with a heavy duty one, Amazon for about $85.
        If you do that take pictures of your wiring before you disassemble it
