led light wiring problem
  • led light wiring problem
    Hello, I am new to this forum but I am in need of some help. I have installed two led light bars, one in the front and one in the back. I am wiring this up on a 48volt Bad Boy buggy with eight 6 volt batteries and going from one positive side of a battery to the third battery in line on the negative side which is giving me 12 volts. The wiring harness has the relay, fuse, switch and all connections on it. I wired it all up and the switch light will come on but the lights will not. I can take the same positive and negative wires and run to the 12 battery on my truck and everything works fine. Can somebody please tell me what is going on.
    Thanks
