2005 EZ GO TXT won't run
  • 2005 EZ GO TXT won't run
    My 2005 EZ GO TXT won't go forward of backward when I press the accelerator pedal. There is a clicking noise however nothing happens. I am a total newbie when it comes to golf cart repair. Do I need to replace the solenoid?
    yes the clicking sound is from the solenoid. You can get one on ebay or amazon. Easy to install also.
      my ezgo 48txt won't go. It started when I replaced the batt cable that goes to the solenoid (it was totally corroded). However I didn't flip switch to 'tow' position and boy did I get some sparking! I yanked the cable away. Then I tried it again and boom another big spark. Then the third time it was just a whimper of a spark so I tightened it down. But then it wouldn't go at all. The backup beeper doesn't work now. I replaced the solenoid and got a refurbed controller and flipped switch to 'tow' this time. Nothing happens. I did notice that the charging port would get warm so I disconnected it from batts. HELP!!!
